TOPIC: Banned..?
Banned..? 14 years 5 months ago #852
Your name ingame: Dagern
Admin who banned you: (If that's known) No.
Reason why you are banned: No idea
Explain why you should be unbanned: Because I love the server and wanna earn points for the scoreboard. I also didn't do anything wrong that I know of, and have never been kicked or warned by admins, to my knowledge.
For some reason I've been blocked from Server #3. Played it last night, found out I wasn't going to be able to finish, so reset myself and left. Have since then even played on different server, but trying to join #3 today was futile.
Help?
  • Dagern
  • Dagern's Avatar Topic Author
Re: Banned..? 14 years 5 months ago #853
Um... Don't think you're banned as you're not on the banlist. Will take a look into this for you. Is it just server #3 you're having problems with? Does it come up with any messages when you fail to join the server?
Regards,
cxc
Re: Banned..? 14 years 5 months ago #854
Half the time it tells me I'm banned, the other half it's some connections issue. Might just be me, but it's only the server in question on which I'm experiencing this issue.
  • Dagern
Re: Banned..? 14 years 5 months ago #860
Okay, working on it :) Bare with us while we deal with the issue. Will keep you posted here.
Re: Banned..? 14 years 5 months ago #861
I believe I have fixed the issue. Let me know if you continue to experience problems :)
Re: Banned..? 14 years 5 months ago #864
I haven't had the issue today, so I can only presume it's been solved. :D
  • Dagern
Time to create page: 0.123 seconds
