TOPIC: Not able to join any servers
Not able to join any servers 12 years 7 months ago #2777
When I try to join any server "You are banned from this server" message appears and I am immediately kicked out of the server. Is this any bug/error in servers or I am really banned?
  • C-DAC
  • C-DAC's Avatar Topic Author
Not able to join any servers 12 years 7 months ago #2778
Hi.
PLease send me trough private message your IP adress please.
You can use this site to find your IP - ipaddress.com/
  • tomate
  • tomate's Avatar
Not able to join any servers 12 years 7 months ago #2779
hi :)
I saw this happens many times (on BTPro and n-ice servers):
Code:
* +ttd-srv3 * !! C-DAC (#3/1 (Blue)) has been detected as open proxy/botnet zombie! Banning player!
This means your current IP is black listed somewhere. You have couple solutions:
- Restart your internet router, till get a new IP;
- Contact your ISP to they take the correct actions to that IP stop being black listed;
Hope it helps :)
Not able to join any servers 12 years 7 months ago #2780
Hi,
I don't have a router and my ISP provides me a dynamic IP, so it keeps changing at random intervals. So both solutions will not work in my case.
I have sent my IP address to tomate as he requested. Hopes he can remove my IP from black list.
  • C-DAC
Not able to join any servers 12 years 7 months ago #2781
Won't be possible to remove, since the check it's made automatically by BOPM .
So, I truly recommend contact your ISP saying that your current IP is being blacklisted by some online services.
Not able to join any servers 12 years 7 months ago #2783
Looks like tomate have solved this problem.
Now I am able to join the BTPRO servers..
Thank you guys for quick help. :)
  • C-DAC
Time to create page: 0.137 seconds
