TOPIC: Website problems
Website problems 12 years 2 months ago #3248
Hello there,
I came by a website bug, one or two actually, though maybe quite minor
First is, that whenever I try to update my profile info, I get denied by this error
The second one is when I want access wiki while being logged at the site, it goes puuf
Really, what is bad with my nickname here? :ohmy:
So there is third one, maybe just a mistake though. There is this Attachments thing under posting area to upload files, but after submiting they simply dissappear. Or am I using the upload form in a wrong way?
So here are the picture reports
profile www.novapolis.net/data/garbage/profile.png
wiki www.novapolis.net/data/garbage/wiki.png
Admin of Novapolis OpenTTD servers, www.novapolis.net
  • TheDude
  • TheDude's Avatar Topic Author
  • Novapolis admin
  • Thank you received: 13
Last edit: by TheDude. Reason: Reuploading files and then reporting it wont upload
Website problems 12 years 2 months ago #3262
well, the only thing I can remember is: the underscore "_" is not accepted since website/forum update. Wich I think you're familiar with ^^
Since I'm not confortable with Wiki stuff... I'll let answer to experienced persons :P
About the attachements: yup, seems not working :(
Anyway, solution is simple ^^
Website problems 12 years 2 months ago #3277
There is another little problem: If you ever use the left o right arrow keys to traverse the reply area (where i'm typing right now. The whole tab freeze's up and you need to open a new one. I am using google chrome if it's a known/chrome only issue
  • IANF
  • IANF's Avatar
Website problems 12 years 2 months ago #3278
IANF, it's a known problem, as said in other 16 or 17 other similar posts (maybe exagerating a bit) but, as explained too that it's a browser issue: example, if you try Firefox or Internet Explorer (yes, even on this), it works! Only Chromium based ones have issues. But ofc, if using any Chromium based browser, simply do this: close the tab that crashed (there's a window for that), and CTRL+SHIFT+T and will appear the window on the edit point. And yes, learnt it the hard way too!
To the ones saying that use Opera... it's Chromium based too, now!
The following user(s) said Thank You: IANF
Website problems 12 years 2 months ago #3316
The sacred rules of webmakers is to provide functional web, not to force users to use some other browsers (it is sometimes very tedious, e.g. with older version of IE, but even today there are quite differencies between browsers).
The arrow problem was there even when old Opera was not old, and I experienced it in IE and mozilla too. If it does not still work in current chrome, it is alarming
Moral of the story: get a good web programmer!!! :D
The following user(s) said Thank You: kraFtzu
  • TheDude
  • Novapolis admin
Website problems 12 years 2 months ago #3324
Well, that would surely help... Are you offering yourself? :-P
Time to create page: 0.146 seconds
