TOPIC: IRC phone problem, unable to connect.
IRC phone problem, unable to connect. 8 years 10 months ago #6260
Hello everyone,
My phone IRC apps won't connect to the server. It seems like the server is actively refusing connections, as i and ST2 both couldn't connect.
The information i used to connect is the same as on the website, i have tried 4 different apps.
Hope you can fix this problem soon.
~Play on
~Play on
  • Lee14141
  • Lee14141's Avatar Topic Author
  • Thank you received: 3
IRC phone problem, unable to connect. 8 years 10 months ago #6261
I got mine working by using one of the leafs, try connect to btpro1.irc.boxor.net
The following user(s) said Thank You: Lee14141
IRC phone problem, unable to connect. 8 years 10 months ago #6264
Works for me, thanks again for solving the problem ST2!
~Play on
  • Lee14141
Time to create page: 0.128 seconds
