  • 3
TOPIC: Max loan amount on servers since 1.2.0? #4
Max loan amount on servers since 1.2.0? #4 14 years 6 months ago #677
I am pretty sure the max loan was not set to 100k on the old Desert Short goal, #4.
Dunno if this is the case on the other servers too, but should probably fix it. :3
  • Zalmar
  • Zalmar's Avatar Topic Author
Re: Max loan amount on servers since 1.2.0? #4 14 years 6 months ago #679
This is a smart, challenging and really player selective decision. The problem come with the type of engines... I mean, with 200k loan you afford easily to buy SH (temperate server), but if you try to play on desert/winter server (were the engines are more expensive) is very hard to have a decent start.
  • meanbrake
  • meanbrake's Avatar
Re: Max loan amount on servers since 1.2.0? #4 14 years 6 months ago #680
meanbrake wrote: The problem come with the type of engines... I mean, with 200k loan you afford easily to buy SH (temperate server), but if you try to play on desert/winter server (were the engines are more expensive) is very hard to have a decent start.
True on that.
  • Goodblue77
  • Goodblue77's Avatar
Re: Max loan amount on servers since 1.2.0? #4 14 years 6 months ago #681
it's not remotely interesting when the only thing you can build is a tiny route with a single train...
The loan was never this tiny previously. It's utterly silly.
Desert is fun for microing multiple train around on a single track without using signals to optimize your start - you don't even have enough cash to do that as it stands now
EDIT: Lower loan does not invite "more interesting gameplay", it just limits people who are a bit more imaginative. Sure you'll have bad players throwing down a big track and only a single train to occupy it, but good players just get limited in what they can do when the loan is stupidly low initially.
  • Zalmar
Last edit: by Zalmar.
Re: Max loan amount on servers since 1.2.0? #4 14 years 6 months ago #682
Right - it may make SOME sense on the Quick server (still against it tbh), but it's entirely too slow and boring on others (Desert).
I have no trouble adapting and can still do ~100k routes with the 200k loan, but it slows down the game far too much and it honestly means I'll be alt-tabbed 50% of the time.
More money = more options = more interesting when you actually know what you're doing.
Using that money correctly is what makes the difference between getting to Goal in 5 or 10 years.
  • Zalmar
Re: Max loan amount on servers since 1.2.0? #4 14 years 6 months ago #684
Yes, you're using other trains, but that doesn't change the fact that it just limits your options. Doing 2 trains on a single track (signal-ignoring) from the start is fun and challenging.
It may force new players to get better but it forces better players to sit on their ass and be BORED.
EDIT: Not to mention, have fun going farms, hahahahaha. Or building on a map that has a large amount of them close together.
  • Zalmar
  • 3
Time to create page: 0.124 seconds
