TOPIC: FIRS changes
FIRS changes 13 years 6 months ago #1741
As we have probably noticed FIRS has changed quite dramatically from before.
Including varied (and often lower) production, lower cargo payment and generally everything is more difficult. Meaning that even the 150 million server could frequently take longer than 20 years.
I was wondering maybe the goals could be reduced or you get more points for the same number of years or something to keep a fairly level point-scoring system, otherwise FIRS will be played even less as someone may get 1 or 2 points for a better game.
  • Jacko :D
  • Jacko :D's Avatar Topic Author
Re: FIRS changes 13 years 6 months ago #1743
Hi
I just played it for the first time and it seemed easier than before, 12 years to complete the 150m.
Looks to be a bit more focused on getting the engineering supplies and farming supplies to the oil wells/forests then their production goes up very fast.
everyone seems to play it a bit different, could just take a bit to get use to.
Cheers
Tyson
  • Tyson
  • Tyson's Avatar
  • Thank you received: 3
FIRS changes 13 years 3 months ago #1936
Hi,
Just wondered if scoring system has changed on FIRS? I just finished a team game in 26 years and instead of both getting 24 points we both got 12. The FIRS scoring used to give all players both the full amount of points. Could someone let me know if it is a delibarate change or an error since some of the changes on the servers over the last week or two?
Thanks.
  • mwise
  • mwise's Avatar
  • Thank you received: 9
FIRS changes 13 years 3 months ago #1939
Ah damn... I didn't think about that when i migrated the openttd instances to a new server :-S my bad.
I will change your points directly in the database when i get to work. And offcourse will change it back to what it was, that is both 24 points.
Thanks for lettingus know, sorry for the inconvenience.
Best regards,
The following user(s) said Thank You: mwise
FIRS changes 13 years 3 months ago #1940
Thank you. That is much appreciated. The other person playing was Dobro.
  • mwise
  • mwise's Avatar
FIRS changes 13 years 3 months ago #1942
Scores + plugin has been altered. Everything should be fine now :-)
You both got 24 points now...
Best regards
The following user(s) said Thank You: mwise, Dobro
Time to create page: 0.168 seconds
