TOPIC: Can't join, red dot. ???
Can't join, red dot. ??? 12 years 10 months ago #2430
Does anyone know why I can't join BTPRO games?
Is it happening/ has happened to anyone else?
I just want to play Citybuilder like I always do :)
The dot is red instead of green and I can't join.
I can join others but not BTPRO, AKA: the one I want to play and can sign in on.
Can anyone help? :unsure:
Thanks, Smash :P
  • Smash
  • Smash's Avatar Topic Author
Can't join, red dot. ??? 12 years 10 months ago #2431
hi :)
probably this is the reason:
!!! BTPro servers upgraded to version 1.3.3! Download latest stable version here or use our client after 1.3.3 installation. Enjoy the games !!!
I guess the solution is: Install OpenTTD 1.3.3!
Tell us if solved it :)
Edit: I removed the other post... was in double ^^
The following user(s) said Thank You: Smash
Can't join, red dot. ??? 12 years 10 months ago #2438
Yes, it worked! Thank you!! :woohoo:
  • Smash
Time to create page: 0.141 seconds
