TOPIC: Btpro 1.7.1 client version problem
Btpro 1.7.1 client version problem 9 years 4 months ago #6097
on linux, downloading and compiling
openttd.btpro.nl/OpenTTD_versions/BTPro_...1_B_17102_source.zip
creates a version mismatch between the client and BTpro servers.
Patching openttd.org 1.7.1 sources with the btpro patch compiles fine and matches the server version.
  • tulkas
  • tulkas's Avatar Topic Author
Btpro 1.7.1 client version problem 9 years 4 months ago #6098
You're right.
Replaced the file. It has same name and if you want to make a try, say something after ^^
Thx for noticing :)
Btpro 1.7.1 client version problem 9 years 4 months ago #6104
works now. problem is fixed.
ty
  • tulkas
Last edit: by tulkas.
Btpro 1.7.1 client version problem 9 years 3 months ago #6118
Tried compiling the BTPro client source today and it gives a server revision mismatch error.
It was the btpro_client_D_17104_source.zip
  • M-Trac
  • M-Trac's Avatar
  • Thank you received: 23
Last edit: by M-Trac.
Btpro 1.7.1 client version problem 9 years 3 months ago #6119
oh crap, not again :(
will check what I can do.
Meanwhile, try a svn checkout with: svn checkout svn://svn.openttd.org/tags/1.7.1
Apply our diff file with: patch -p0 < file.diff
From here must all work correctly (while I check what's wrong with our source file ^^)
Btpro 1.7.1 client version problem 8 years 7 months ago #6494
Hi,
I tried downloading and building today with the 1.7.2 and we seem to have the version mismatch bug again. The svn clone and diff apply works. I can help with generating a new zip file, or updating the install instructions to get the sources by svn. I think maybe that'll be more maintainable in the long run - there's not much added cost for the user to get the sources by svn and apply a patch.
T
  • Falketind
  • Falketind's Avatar
Time to create page: 0.134 seconds
