TOPIC: [OUTDATED] Compiling & Running on Arch Linux
[OUTDATED] Compiling & Running on Arch Linux 8 years 9 months ago #6330
I'll preface this with thanking you guys for the BTPro client.
Make a file with these contents:
Code:
#!bin bash cd Documents mkdir openttd-btpro cd openttd-btpro # Openttd mkdir openttd-btpro cd openttd-btpro curl http://termbin.com/4zkf > PKGBUILD curl http://openttd.btpro.nl/OpenTTD_versions/innerhighlight.grf > innerhighlight.grf curl http://openttd.btpro.nl/OpenTTD_versions/BTPro_Client_1.7.2_A_17201.diff > BTPro_Client_1.7.2_A_17201.diff makepkg -si cd .. # Opengfx mkdir openttd-opengfx-btpro cd openttd-opengfx-btpro curl http://termbin.com/hgfl > PKGBUILD makepkg -si cd .. # Opensfx mkdir openttd-opensfx-btpro cd openttd-opensfx-btpro curl http://termbin.com/jm9u > PKGBUILD makepkg -si cd .. # Openmsx mkdir openttd-openmsx-btpro cd openttd-openmsx-btpro curl http://termbin.com/0hh7 > PKGBUILD makepkg -si
Run chmod +x on the file then run it.
Tada! Now you can start openttd with "openttd-btpro"
I'd recommend one of the BTPro devs to push my 4 pkgbuilds to AUR (as 4 separate packages). I'd do it my self but I don't want to maintain it. :p
  • gentz
  • gentz's Avatar Topic Author
Last edit: by gentz.
Compiling & Running on Arch Linux 8 years 9 months ago #6331
At first, I'm happy that our client was built and worked on an Arch Linux user environment.
All this happened among chats on another community IRC channel but gentz , on his own, decided to share here how he made it.
Personally I only test our BTPro client on Debian and Fedora Linux based systems to see if it compiles and runs. Linux has so many distros that it's impossible to test them all.
Note: when I compile, I usually use "make bundle". This way I'll get the needed files on a "bundle" folder to run the game. But, that's me, and on the environment's I told above.
For this, Thank you. Maybe other players can see, ask or make other suggestions about it. All replies are welcome :)
Compiling & Running on Arch Linux 8 years 9 months ago #6332
I've simplified the process by making openttd-btpro use the same directories as openttd however this means you can't have both installed at the same time. But that shouldn't matter as the btpro client support vanilla games.
Now all you got to do is this:
Code:
cd Documents mkdir openttd-btpro cd openttd-btpro curl http://termbin.com/hz8q > PKGBUILD curl http://openttd.btpro.nl/OpenTTD_versions/innerhighlight.grf > innerhighlight.grf curl http://openttd.btpro.nl/OpenTTD_versions/BTPro_Client_1.7.2_A_17201.diff > BTPro_Client_1.7.2_A_17201.diff makepkg -si
Now you can run openttd with "openttd" instead of "openttd-btpro"
EDIT: Can any admins pin this post to the top so people see this one first?
EDIT2: Updated where the innerhighlight.grf goes, for some reason it broke itself
  • gentz
Time to create page: 0.125 seconds
