TOPIC: BTPro Client 1.8.0
BTPro Client 1.8.0 8 years 6 months ago #6504
Downloaded and installed the new client 1.8.0. Installed OS is Windows 10. Installation and operation works very well. Good job folks.
  • Utslagsnes
  • Utslagsnes's Avatar Topic Author
  • It's hard to be humble when you are norwegia
  • Thank you received: 5
BTPro Client 1.8.0 8 years 6 months ago #6505
Thank you Utslagsnes for the kind words,
Probably not many players noticed this:
Code:
- Feature: Add option to close windows with right click
It's OFF by default, but can come in handy ^^
Full changes here
Enjoy the games :)
Edit: screenshot of " option to close windows with right click" on settings
The following user(s) said Thank You: Anni, Tobus, tomb, r5, HCL, lordbanastor
BTPro Client 1.8.0 8 years 6 months ago #6506
thanks guys and gals, now I reached the 420 "Thank you received", if you know what I mean ^^
Enjoy the games :)
BTPro Client 1.8.0 8 years 6 months ago #6507
My Avast decided to send the executable for analysis that will take up to 123 minutes lol wtf this never happened before
  • kraFtzu
  • kraFtzu's Avatar
BTPro Client 1.8.0 8 years 6 months ago #6513
evening all, not sure what i have done wrong... followed the usual instructions. but my Language files are messed up. OTTD is openning in the first Lang in the folder (afrikaans) delete that and it loads in Arabic, delete all those above english and it says that language files are missing. . .
I have uninstalled and reinstalled the game and the Client, no luck.
Help?
  • LexusGris
  • LexusGris's Avatar
BTPro Client 1.8.0 8 years 6 months ago #6514
It's really weird, but lets see if we get somewhere ^^
Because Windows is very picky with his Programs folder (default folder for installation), try this steps:
- Uninstall OpenTTD;
- Install it again on a folder outside Windows Programs folder (example: C:\Games\OpenTTD);
- Create an empty openttd.cfg file on same place the executable is (must be enabled to view file extensions - OpenTTD will fill the empty file on first run);
- Extract the files of BTPro client to there, replacing the executable and land folder;
- Open the openttd.exe file properties, Compatibility tab and enable the option to "Run this program as administrator" (bottom);
- Make the first run now;
If after this steps you have same issues, join our IRC (details in Contact Us and we'll try to find a solution :)
The following user(s) said Thank You: LexusGris
Time to create page: 0.143 seconds
