TOPIC: Tool to learn how town growth works
Tool to learn how town growth works 10 years 2 months ago #5485
Dont know if this has been posted already on BTPro but here it goes anyway:
citymania.org/tools/townsim
Read the text below the simulator window to learn how to use it. With this tool you can see what you are doing wrong in your layout. See where your errors are and what it causing them. Also how the growth works in-depth.
Here's an example: i.imgur.com/KvNGv1j.png
Have fun!
Thx to >> dP << who make these sweet tools!!!!!! <3 :D
//Magnus 'Saber' Jonsson
The following user(s) said Thank You: ST2, tomb
  • Saber
  • Saber's Avatar Topic Author
  • Premium Member
  • Premium Member
  • FrankerZ
  • Thank you received: 34
Last edit: by Saber.
Tool to learn how town growth works 10 years 2 months ago #5486
Thank you, Saber, very much. What a nice tool :cheer: dP did a great job!
Yours example is also great. But what can I do if I'm aware of big "svastika" performance and I don't like it very much? ;) I use it only during 25k games. In each game below 25k I make loops and CS is going high.
  • tomb
  • tomb's Avatar
  • Thank you received: 236
Last edit: by tomb. Reason: typos
Tool to learn how town growth works 10 years 2 months ago #5487
tomb wrote: Yours example is also great. But what can I do if I'm aware of big "svastika" performance and I don't like it very much? ;)
By "big swastika" you mean double spiral ? What is that you don't like about it? It's the best layout unless you can use simpler spirals (for 4k mb).
Considering btrpo's crazy pop-based growth you can try doing some shenanigans to free more space in center but I've never heard of anyone being successful with it.
  • dP
  • dP's Avatar
Last edit: by dP.
Tool to learn how town growth works 10 years 2 months ago #5488
By "big swastika" you mean double spiral?
I think I always try to build something which should be called "tripple spiral" using your naming convention. I also prefer playing on desert, where water and food should be also delivered. I transport them using trains, I think I should do it by air to keep spirals perfect. But I like trains entering the city!
I know I should not compare the game to real life. However, lack of road crossings in the cities is the only thing hard to accept for me. Maybe because I got used to them in old times, when there were no CB scripts and I was not thinking about city grow mechanics. And up to now, just for "visual satisfaction", I make crossroads in the cities. But spirals are unevidable if you need olympic-level results ;)
Agreed.
...free more space in center...
Even more "crazy" idea than spirals ;)
  • tomb
  • tomb's Avatar
Last edit: by tomb.
Tool to learn how town growth works 10 years 2 months ago #5489
tomb wrote: I think I always try to build something which should be called "tripple spiral" using your naming convention. I also prefer playing on desert, where water and food should be also delivered. I transport them using trains, I think I should do it by air to keep spirals perfect. But I like trains entering the city!
Triple like this? Hm, according to emulator it's ok, almost good as double)). Even though it has unequal probabilities for roads you need at least 50k town to notice it. And you can always put two-platform stations between roads without disturbing layout.
tomb wrote: I know I should not compare the game to real life. However, lack of road crossings in the cities is the only thing hard to accept for me.
Well, yeah then there isn't much you can do here. If you have loops you're bound to have CS and waste some precious central house spots. And the more and smaller loops you have the worse layout gets. You can do some decent infinitely branching layouts with more crossroads than spiral, but that's probably not what you're after either xD
  • dP
  • dP's Avatar
Tool to learn how town growth works 10 years 2 months ago #5500
Yes, that's the spiral I usually use. Yesterday I tried double spiral in the game, and it was great, as expected. I think I've just got used to it xD
  • tomb
  • tomb's Avatar
Time to create page: 0.305 seconds
