TOPIC: CB 15 Raising land for docks / oil rigs not working?
CB 15 Raising land for docks / oil rigs not working? 6 years 6 months ago #7174
Hi all,
Played a game in CB15 tonight and it seems as if oil from oil rigs is no longer loading at docks near oil rigs (when you have raised land to place one -- in compliance with rule #9). The individual oil rigs do load oil however.
Bug or intended?
  • M-Trac
  • M-Trac's Avatar Topic Author
  • Thank you received: 23
CB 15 Raising land for docks / oil rigs not working? 6 years 6 months ago #7176
I guess it is due to the following change introduced with 1.10.x
github.com/OpenTTD/OpenTTD/pull/7204
github.com/OpenTTD/OpenTTD/pull/7234
Btpro needs to enable "Company stations can serve industries with neutral stations" if they wish to restore such behaviour.
The following user(s) said Thank You: Frank, ST2, malbec, M-Trac
  • Myhorta
  • Myhorta's Avatar
  • Thank you received: 12
Last edit: by Myhorta.
CB 15 Raising land for docks / oil rigs not working? 6 years 6 months ago #7193
The "serve_neutral_industries" it's set as true by default. Intentionally I changed it to false to make it easier to players follow our rule #9 and use the neutral station the industry have (usually by ships). On servers that have longer goals (example server #K1) and industries with own stations spawn a bunch more (oil rigs, for example) makes sense to keep it true, allowing the usage of docks to cover multiple industries. Therefore, and opportunely, setting will be put to normal behaviour on server #15. Thanks for understanding.
Suggestions are welcome... Enjoy the games :)
The following user(s) said Thank You: Frank, M-Trac, tomb
Time to create page: 0.131 seconds
