TOPIC: Small change in setting
Small change in setting 14 years 1 month ago #1209
Is it possible to change yapf.rail_firstred_twoway_eol setting to on?
It would help a lot in advanced constructions like owerflows, logic and others. For gerenic player there is no change, but for advanced players there are new possibilities of building.
So, think about it.
  • King Peky
  • King Peky's Avatar Topic Author
Re: Small change in setting 14 years 1 month ago #1229
Will take a look at the settings, and come to a conclusion soon! Just need to check some things out first.
Re: Small change in setting 14 years 1 month ago #1232
Only change is if the train will arrive to twoway signal which is both side red it will take another way around it.
More about it is at wiki.openttdcoop.org/Penalties#yapf.rail..._twoway_eol_.3D_true
  • King Peky
Re: Small change in setting 14 years 1 month ago #1240
Will do a trial of this setting on our two long goal servers. Server 2 temperate and server 5 desert, and see how it goes. The change hopefully should be made tomorrow when I get home from work. Will post here to let you know it's done.
Happy gaming
Small change in setting 12 years 10 months ago #2421
FIFA 14 IOS Coins
  • markjosol
  • markjosol's Avatar
Time to create page: 0.129 seconds
