TOPIC: How I can make automatic replacement for the same
How I can make automatic replacement for the same 14 years 2 months ago #1180
How I can make automatic replacement for the same vehicle?
Beacuse because when they become old need replacing.
Thanx!
  • Terror
  • Terror's Avatar Topic Author
Re: How I can make automatic replacement for the same 14 years 2 months ago #1181
ITs a serverside settings,
And by the looks of it its turned on. (advanced settings menu)
  • solo
  • solo's Avatar
  • Thank you received: 17
Re: How I can make automatic replacement for the same 14 years 2 months ago #1182
Yes, I found the option in advanced settings menu, but it doesnt works :(
  • Terror
Re: How I can make automatic replacement for the same 14 years 2 months ago #1191
Depends on a certain few factors such as the train you were using (because it updates with the same model) and the ingame year. Hence if you're using a train that came out in 1965 then it will be unavailable to buy once the year reaches 2000ish. Hence that train can not be automatically replaced with the same model. So you need to change that train manually into one that can be bought at the depot.
Hope that helps!
Re: How I can make automatic replacement for the same 14 years 2 months ago #1200
Thanks for the explanation, really help :)
  • Terror
Time to create page: 0.186 seconds
