TOPIC: Is there any easy way to upgrade tacks and trains
Is there any easy way to upgrade tacks and trains 14 years 1 month ago #1214
Is there anyway I can upgrade everything without having to put them all depots and manually changing them?
  • OffTheRicta
  • OffTheRicta's Avatar Topic Author
Re: Is there any easy way to upgrade tacks and trains 14 years 1 month ago #1215
If you on about Electric to Monorail to the best of my knowledge the answer is no, I find the best way is just to build a monorail/maglev depot next to the existing one and build trains then send the old stock to the depot before quickly converting all the rails.
Dodger
  • dodger007
  • dodger007's Avatar
  • Thank you received: 19
Time to create page: 0.125 seconds
