  • 3
TOPIC: Keyboard shortcuts
Keyboard shortcuts 12 years 8 months ago #2624
Hello all. I've recently returned to OpenTTD and having played a few years ago I gotta say I really like the improvements, ease of login, etc. I wanted to started a topic/discussion about keyboard shortcuts. I play on 7 100% of the time right now and I'm not leaving there until I can complete a game in under 2 hours. I'm constantly looking to improve my game and like to play around with keyboard commands to try and help me become more efficient. So I've got one question and then I was hoping some would contribute of the shortcuts they most commonly used
Is there a keyboard command to make a window sticky? I like to keep a fair amount of windows open when starting and am wondering if there is anything I could do to make this efficient. Apologies if something like this has already been started/posted but I didn't find anything like this.
Good gaming all.
-TJ aka Bubba
  • Bubba
  • Bubba's Avatar Topic Author
Keyboard shortcuts 12 years 8 months ago #2625
Hi TJ,
I don't think there is a keyboard shortcut for making windows sticky, just the pin in the top right corner unfortunately. When closing down stickied windows you can use "SHIFT+DEL" though to close all windows ("DEL" will just close the non-sticky ones).
In terms of shortcuts and hotkeys that I use the most:
[terraform]
lower = GLOBAL+Q
raise = GLOBAL+W
level = GLOBAL+E
dynamite = GLOBAL+D
autorail = GLOBAL+A
station = GLOBAL+R
signal = S (when rail toolbar open)
bridge = B (when rail/road toolbar open)
tunnel = T (when rail/road toolbar open)
autoroad = GLOBAL+S
toggle_transparency = X
Just in case you're not aware, you need to be careful when using some of the hotkeys when you have other windows up. For example, pressing D when you want to use the dynamite tool will skip a vehicle order if you have the vehicle orders window up.
Hope that helps a bit. A list of all the hotkeys can be found in the hotkeys.cfg file if you want to look at more.
BigCheese
  • BigCheese
  • BigCheese's Avatar
Keyboard shortcuts 12 years 8 months ago #2626
I'll post my hotkeys too then. Mine are kind of final. Some small edits still needed on some buttons. But im waiting for dP to add spacebar + TAB key :)
[global]
console = BACKQUOTE
delete_windows = ESC
transparency_toolbar = CTRL+X
chat_all = SHIFT+RETURN
chat_company = RETURN
[maintoolbar]
small_screenshot = F12
client_list = F4
build_hq = F6
trees = GLOBAL+6
[terraform]
lower = GLOBAL+Q
raise = GLOBAL+W
level = GLOBAL+E
placesign = GLOBAL+F5
[order]
skip = 4
delete = 3
goto = 1
[airtoolbar]
airport = GLOBAL+F3
[railtoolbar]
autorail = GLOBAL+A
demolish = GLOBAL+D
depot = V
station = C
signal = GLOBAL+S
bridge = F
tunnel = G
remove = R
convert = T
[roadtoolbar]
autoroad = GLOBAL+Z
depot = V
bus_station = B
truck_station = C
oneway = T
bridge = F
tunnel = G
remove = R
[depot]
depot_go_all = 2
depot_build_vehicle = 1
depot_clone_vehicle = 5
[vehiclegui]
vehicle_orders = 1
vehicle_go = 2
[town_view]
fund_buildings = F1
build_statue = F2
(making orders shortcuts)
CTRL+click = full load any cargo
SHIFT+click = Transfer
ALT+click = Unload all leave empty
Questions? =)
Edit: BTW why do u want a shortcut for sticky? to clone trains? If you have 1080p screen u can have 2-3 trains open at once without a problem(stickied ofc) once uve sticky u dont wanna remove it anyway so why need a hotkey for it?
BigCheese thats why u move skip key to 4 ;)
//Magnus 'Saber' Jonsson
  • Saber
  • Saber's Avatar
  • Premium Member
  • Premium Member
  • FrankerZ
  • Thank you received: 34
Last edit: by Saber.
Keyboard shortcuts 12 years 8 months ago #2628
Saber, i hope you know im trolling, but if you press ESC, it deletes ur Windows op system? :lol:
however to answer to the question as well:
i usually build mostly trains, so i dont really care about RV shortcuts.
if u want to build railroad fast, then learn to do it with autorail (press A), its much faster than the other way, and press ctrl to remove rail. so with A and ctrl u can build rail really fast, and thats great, cuz on a company value server u want to do it the most.
jah, and a new feature in btpro client, when giving orders if u press ctrl while giving the order, that will be "full load", and shit for "transport and leave empty".
these are the tricks helped me to build quite really fast.
  • NaB
  • NaB's Avatar
Keyboard shortcuts 12 years 8 months ago #2629
dat troll ;)
  • Saber
  • Saber's Avatar
  • Premium Member
  • Premium Member
  • FrankerZ
Keyboard shortcuts 12 years 8 months ago #2630
but then what is that delete_windows? :P
jah and forgot something, theres a quite great thing in the btpro client, when u move ur cursor on a economical building, it shows how much it produces, u can save several clicks with this feature.
  • NaB
  • NaB's Avatar
Last edit: by NaB.
  • 3
Time to create page: 0.134 seconds
