  • 3
TOPIC: Most keyboard shortcuts don't work
Most keyboard shortcuts don't work 12 years 1 month ago #3459
Haven't been around for a while. Now when I play, the game behaves strangely. Some keyboard shortcuts work (F1-F12, Ctrl+1 - Ctrl+9, Shift+Ctrl+1 - Shift+Ctrl+8, Shift+Ctrl+F1 - Shift+Ctrl+F12) but most others don't - X for transparency, M for map, A for rail contruction.. etc etc.
I use a compiled 1.4.2 BTPro version but when I tried 1.3.3 from Ubuntu packages the behavior was exactly the same.
I didn't make any changes to hotkeys.cfg.
@Ubuntu 14.04
  • au
  • au's Avatar Topic Author
Most keyboard shortcuts don't work 12 years 1 month ago #3463
Move it and let it make a fresh one?
//Magnus 'Saber' Jonsson
  • Saber
  • Saber's Avatar
  • Premium Member
  • Premium Member
  • FrankerZ
  • Thank you received: 34
Most keyboard shortcuts don't work 12 years 1 month ago #3465
Saber wrote: Move it and let it make a fresh one?
This behavior was when I had no hotkeys.cfg. And after I created an empty hotkeys.cfg file, the program filled it with default values but still exactly the same behavior.
  • au
Most keyboard shortcuts don't work 12 years 1 month ago #3469
I am not sure how the game behaves on Linux but on Windows it creates a folder in My Documents that it uses for storing saves, screenshots and cfg files. If you have multiple clients instaled they will all use this folder unless you create a cfg file inside game instalation folder - then the game will use files from instalation folder and will also store all saves and screenshots in there.
So, maybe you have some corrupted hotkey.cfg in your instalation folder?
  • kraFtzu
  • kraFtzu's Avatar
Most keyboard shortcuts don't work 12 years 1 month ago #3473
Try using the original client or download a fresh zip/unzip and launch.
This has happened to me also quite some patches back.
  • Saber
  • Saber's Avatar
  • Premium Member
  • Premium Member
  • FrankerZ
Most keyboard shortcuts don't work 12 years 1 month ago #3478
krawco wrote: I am not sure how the game behaves on Linux but on Windows it creates a folder in My Documents that it uses for storing saves, screenshots and cfg files. If you have multiple clients instaled they will all use this folder unless you create a cfg file inside game instalation folder - then the game will use files from instalation folder and will also store all saves and screenshots in there.
in Linux it's in ~/.openttd; I deleted this dictionary and purged all previous installs. I also searched for hotkeys.cfg and there are none except in my new installs in the same dictionary as the executable.
Saber wrote: Try using the original client or download a fresh zip/unzip and launch.
I compiled 1.4.2 original version and 1.4.2 BTPro and tried 1.3.3 from Ubuntu repositories, the same behaviour in all cases.
  • au
  • 3
Time to create page: 0.184 seconds
