TOPIC: Transforming Toyland into Temperate
Transforming Toyland into Temperate 8 years 7 months ago #6488
Maybe your eyes keep hurting, because of Toyland optic??? :D
So this will help you to transform the graphics into Temperate in 4 simple steps.
1. Check download content in the OpenTTD main menu and download:
--> Toyland Temperate Replacement NewGRF <--
[img
2. Close your OpenTTD client and open the file 'openttd.cfg' with Notepad or another text editor.
(normally you find this in 'C:\Users\<USERNAME>\Documents\OpenTTD' (for Windows)).
3. Insert the following line to [newgrf-static].:
4A530AB2|077F137989E646972C5BCBD299C1B50F|toyland_temperate_replacement-2012.10.12\removetoyland.grf =
(after that, don't forget to save your file)
[img
4. Restart your OpenTTD client and check out a Toyland map.
Now it should look like this:
[img
Finish
Protect your eyes and enjoy gaming OpenTTD! ;)
Greets
HCL :)
#German Democratic Republic (GDR) Power :P
The following user(s) said Thank You: Frank, ST2, Bahnmeister, Anni, Wacko1976, tomb, r5
  • HCL
  • HCL's Avatar Topic Author
  • Thank you received: 22
Last edit: by HCL.
Transforming Toyland into Temperate 8 years 7 months ago #6490
great work, thx :)
  • Bahnmeister
  • Bahnmeister's Avatar
  • Thank you received: 8
Time to create page: 0.149 seconds
