TOPIC: CB server Company create after voterestart
CB server Company create after voterestart 7 years 11 months ago #6841
Was bit hard to put good subject to this, but i´ll try to explain.
I joined to play in server#32, used token to login, didn´t create any company yet.
I was alone in that server and since i wanted to play desert map, then i used !voterestart until i did get wished climate.
After server restart, since i returned under 600 seconds with same IP address and name, auto-login was performed to my account.
Pressed that token window, get login, got response i´m already logged in.
If you follow then in the end there is a question:
At this point my name in clients list is still being shown as "Player".
When i create company, my Client name changes to Trumsi, but "company name" and "manager name" is set automatically to "Player transport". And it can´t be changed, before you place HQ. When HQ is placed, city is claimed as "Player transport Town". At this point you can change company "manager name" and "company name" to your desired one. But under city name, it still stays as "Player transport Town" and doesn´t change after you re-name your company to new name.
Now question time
Is it something a Player can do from their side (expect from logging back in, later than 600 seconds, before creating company), so that when you create company after server restart, your company name isn´t automatically named as "Player transport" and city claimed as "Player transport Town"?
  • Trumsi
  • Trumsi's Avatar Topic Author
  • Thank you received: 16
CB server Company create after voterestart 7 years 11 months ago #6844
the simpliest answer is: if you create a company named as "Player" ofc the company will be named "Player Transport" (or town name of first action when Player Transport is already taken). The "auto-login" is performed accordingly info the server controller had on you before the restart, even when joining with another nick or no nick at all (Player). You can, from the start, set your nickname on the Multiplayer lobby:
or, when already logged in, change it later with !name *** command, in case you join with any other nickname that not the registered one. So, my suggestion is: don't create a company when named as "Player" because, as said, company will be named "Player Transport". You can change that info later AND before claim a town, in the Company window:
...but my suggestion is to create a company already with the nick you want to be used ^^
Hope it helps :)
The following user(s) said Thank You: Trumsi
Time to create page: 0.246 seconds
