TOPIC: signal tutorial
signal tutorial 14 years 10 months ago #36
does someone know a good signal tutorial?? i get the basics but dont understand the pre-signal and combo signal & exit-signal... i searched youtube but couldnt find much
a text tutorial would be great to :)
  • Barg
  • Barg's Avatar Topic Author
Re: signal tutorial 14 years 10 months ago #40
As the best admin here,
Ill share my knowledge.
The simplest way of using signals is using the last signals (one-way signals). With this signals you make a one way rail for your train. Also with this signals you are able to make 2 basic types of stations.
1. simple station with entrance and exit on the same side of station. That means you use a cross to connect 2 one-way rails and lead them to station.
2. simple station with entrance and exit on opposite sides of station. That means one-way rail leads to station from f.e. bottom and on the oposite site there is a rail out of station.
The 2nd type of station is much faster because you avoid stopping trains when crossing.
But .. check this site verplant.org/openttd/construction.shtml
You will find everything you need.
God is real. Until it was declared as integer.
  • Falco
  • Falco's Avatar
Re: signal tutorial 14 years 10 months ago #45
Have you seen the openttd wiki?
This helped me a lot regarding signals:
wiki.openttd.org/Signals
Hope it helps.
Cyril
  • Cyril Lord
  • Cyril Lord's Avatar
  • This is gameplay you can afford
Re: signal tutorial 14 years 10 months ago #55
thanks, i knew the trick you told and also checked the wiki so hopefully my trains will crash less now haha
  • Barg
Time to create page: 0.153 seconds
