TOPIC: OpenTTD over remote connection
OpenTTD over remote connection 14 years 6 months ago #739
Hi
Has anyone been able to run openttd over a remote connection in windows 7 with out the mouse lagging?
Or any other platform?
Thanks
  • Tyson
  • Tyson's Avatar Topic Author
  • Thank you received: 3
Re: OpenTTD over remote connection 14 years 6 months ago #740
im assuming you play openttd on a different computed you have access to.
the mouselag comes from the delay between the computers not much to do about it i think.
i do it sometimes myself but then im only having 20-25 MS so its barely noticeable.
i am guessing 100+ would cause some trouble playing properly.
Keeping BTPro.nl servers troll and cheat-free! beware!
  • Ivanoz
  • Ivanoz's Avatar
  • There is no spoon!
Re: OpenTTD over remote connection 14 years 6 months ago #742
The mouse is fine in normal windows areas but when in the game it lags by 500ms to 750ms at a guess.
It is pretty unplayable.
Might try vmware to see if it is any better
any ideas would be a great help.
  • Tyson
Re: OpenTTD over remote connection 14 years 5 months ago #769
What were you using agian to connect Ivan?
Thanks
  • Tyson
Time to create page: 0.134 seconds
